MOA_Chaser
- Chicora, PA
- SX
OK, I know that you suck out the oil, measure it, and put back in exactly what you took out.
But last year, I did this, and eventually I got a low oil light. I went out on the water and put in enough oil to get onto the dipstick, and of course the light went off. We used it for the rest of the summer.
I just did the spring freshening of my boat; oil and plugs. I got 1 quart out of the port side, and less than a quart out of the starboard side. Just to be sure... on these boats, you can look down into the holding tank and you should see a round hole in the bottom that gives you like another inch, and a slanted vent hole to the left and right of the center hole, right? I was unable to get the oil tube down any further than the hole in the center.
That seems REALLY low. Maybe I just had enough to keep the light from coming on? Obviously my oil levels are not what they should be. Should I just take it out onto the water on a calm day, run it real good for several minutes, then check the oil level and add to each engine until it's between the lines on the dipstick? I wonder how the dealers know exactly how much to put in the engines...
