Hydrophase Ridesteady Error
mschneider2185
Trout Run, Pennsylvania
Does anyone here have the Hydrophase Ridesteady installed? If so have you ever had it give you an error after about 10 minutes or when you go full throttle?
Mine just started last weekend giving an error and it would lose engine sync and give me an error. In order to go above the pre-set RPM range while it was engaged I had to manually drop each engine back to neutral and then I could go full throttle again but the ridesteady gave an error and would not work again until power was cycled. It seems like it happens after I go WoT for a few minutes. Any input would be greatly appreciated.
white2kstang
Austin Texas Area
I havent had any issues like that so far. Have you reached out to @Ridesteady yet? He has been helpful when I had questions.
zipper
Boston Whaler
Based on your description of your boat...2016 AR, 19', you have one engine. What is to sync?
mschneider2185
Damn forgot to change my info. I did have a 190. Last summer bought a used 240 that came with hydrophase already installed. Sorry about the confusion. @Ridesteady I'll shoot ya an email here today.
Thanks everyone!!
