rzrcrazy2014
- 195S
OK, This is my dilemma. I have narrowed my choice down to 2 boats the 2021 Yamaha 212SD or the Scarab 215ID. I do not want the wake edition on either boat. I am leaning towards the Yamaha, but the open loop cooling system scares me. I am from the automotive industry and I see what damage just using tap water or wrong coolant can do to a cooling system. The thought of all of that trash-silt-sand-weeds running through the coolant passage ways in the block baking on the walls from the heat of the engine and plugging / restricting the flow makes me ponder why open systems are still in use. I will be using this boat in a 50/50 use between inland lakes and around Florida keys. Since I have no experience and I am completely new to all of this I need some advice. 1st is the open loop cooling system as detrimental to the engine as I imagine? Does Yamaha use a sea strainer ? Any pros or cons to either boat from current owners would also be helpful. Does Yamaha allow you to pick any options other than hull color? That is the only option I see on the web site. Last which boat would you buy and why. PLEASE BE CIVIL. I know we have haters on both sides. I am just looking to educate my self. Thank you to everyone that takes time from their busy day to respond to me and help out.
