FLJetBoater
- 242 Limited S E-Series
Thanks! The stuff that's basically almost on fire (it was smoking for a bit) in the can looks like normal gelcoat. So maybe there's hope lol.Oops.
Well, you are where you are, right? Cover it and let it sit until tomorrow. Then evaluate. It will either be fully hardened and look and feel like normal gelcoat or... not. If so, sand and polish it up and call it a win. If not, sand it up a bit to even it out, Dremel out the bad stuff and try again.
That's the nice part about gelcoat. Even when you screw it up, there is grace and redemption.![]()
Did see on some other sites that the MEKP basically just causes a reaction which heats the gelcoat which causes it to cure. So, too much may not do anything bad aside from shortening your working time as the temperature increases too fast.
