ripler
- Just south of Pittsburgh
- MasterCraft
- Other
Until I removed it and saw this. The pin that is a mess is connected to ground and the yellow part is supposed to be part of the connector.
Connector from above voltage regulator.
I decided to try and swap the voltage regulators to confirm it's bad. I removed the good voltage regulator and this is how it looks, same pin has some damage.
Connector from good voltage regulator.
I cleaned up the voltage regulator that I thought was bad and plugged it into the engine that had the good one and it worked.
So I'm thinking the connector is bad which I thought was good news, but I can only find the whole harness for 800.00 and from the looks of it both of mine are bad.
Which leads to the question why did this happen to both harnesses on the same ground pin? And can anyone identify the connector?
