David Martin
- Punta Gorda
- SX
Hey guys I just had an ignition switch break............the plastic housing broke away from the thread barrel. I could hold it together after removing it from the dash so I was able to start it to get off the bay today. I did have a jumper wire for a hot wire start if need be but it was not needed. Has any one wired in a non Yahama key switch..............it kinda makes me shake my head as to why a set of plastic switches sell for $246 dollars......seriously it just a 3 position marine switch with a couple of extra pass through wires to activate the safeties like the rear hatch, neutral throttle ect.
I have the wiring diagram so wiring in a new switch is not imposable, but I Just thought if SOMEONE HAS GONE BEFORE ME it would be helpful as to what switch you chose..................most 3 position marine switches for Yamaha outboards are universal 8 wire setups so you can wire it many different ways to activate different safety devices and thay are in the $25 dollar range not $245
Thanks in advance!!!!!!
