Impellers: New vs Refurbished
Hezi
Secaucus NJ
212S
My 242 performance reduced since I installed new impellers +-60 Hrs ago. I can easily tell since the boat doesn't reach the same top speed and doesn't accelerate as good as before. I am planning to do some deep sea fishing this coming season and I want my boat in top shape. Better impellers will result better fuel consumption.
Here is my dilemma;
SBT will exchange for $98.85 a piece.
Impros will assess and charge anywhere from $100 to $160 per piece.
New Impeller will run $160. PowerSports parts 4 less, Yamaha parts, Sea Doo, Polaris, Tucker Rocky, Accessories, ATV, Motorcycle, UTV, PWC, Jet skis, Trailers
Does the saving (or the lack of) in refurbishing worth it? (I still need to pay for shipping on all 3 options but new will run probably the least $$). Is the quality of a new vs renewed similar? not?
Please share your knowledge and opinion since I want to pull the trigger on this one
Which impellers did you put in the boat?
Current impellers are OEM. Prior ones (which I saved and potentially will send for repair) are OEM as well since I had them replaced at 40 Hrs.
Strange that putting a set of OEM impellers didn't get it back to where it should be. Did you make sure that you are not missing any sealant around the pump tunnel? Any air voids will cause sub par performance. Also check your liner to impeller gap. Beaching/ shallow water running the boat a lot may cause excessive liner wear.
I overhauled the pumps meticulously. I used every step in the repair manual. I even replaced the wear rings and the boat became a monster! I would top over 50 MPH. But this was 2 seasons ago and I do beach A LOT! I'm sure I ingested and pushed some solids through the pumps since the overhaul. I don't think I would bother replacing the impellers now if it wasn't to my ambitions to fish 50-70 miles off shore .
