bronze_10
- Raleigh / Wake Forest Area..
- SX
If not cavitating I would dress them up with a file and replace them in the winter if you're not happy with them.That is what I am considering... in any case it will be a winter mod.
Thanks for posting, always fun to look at pics. I would agree with @Gym - your leading edge damage is not bad (easy to file off) and, importantly, your outside edges (OD) appear pristine. Unless there is something else we can not see here, I would be surprised if you noticed any improvement after swapping or refurbishing the impellers.Here are images of my impellers... I want to hear what the group says. I have never messed with them before..
Starboard...
Port...
Lmao... yes .y pictures are reversed... I posted it laying on the ground under the boat... lol I didn't notice it until you said something...Thanks for posting, always fun to look at pics. I would agree with @Gym - your leading edge damage is not bad (easy to file off) and, importantly, your outside edges (OD) appear pristine. Unless there is something else we can not see here, I would be surprised if you noticed any improvement after swapping or refurbishing the impellers.
And one more thing: Are your pictures labeled in reverse (the top is really of port impeller and the bottom pic is starboard)? Or - you may have the impellers installed on the wrong side... (port OEM impellers usually have these notches in the neck). I bet it is the former. But if not, that could explain your higher max RPMs on the starboard engine, as the port OEM impeller is pitched higher (at least at the trailing edge which will influence RPM).
Uhhhh... where are they? I took those pictures by wedging my phone into the intake gates... I may can wedge my old go pro in there and see if I have more room... where exactly are the numbers?
