ArmyChief
- North Port, FL
So, after getting the boat (2015 - AR192) home last month..the wife and I tried to get it into the garage by ourselves. Needless to say...it was a chore and finally the neighbors sons saw us struggling and came over. After that, I started researching this and the "other" board for options. It appeared some were looking at a trailer jack device that had a crank handle on it. On YouTube, I saw some interesting things being done with a battery powered drill. All these options were not the most reliable and were still $200-$300 options.
So, my thought was to install a winch in the garage and PULL the boat in. Finding a 120 VAC Winch that was cost effective was looking futile. I then considered a 12VDC ATV/Vehicle bumper mount winch as a more cost effective option. However, using a 12VDC winch would also entail a 12 V battery and charger. I then looked at one of my favorite stores…. Harbor Freight. Harbor Freight, had a 1500 lbs 120VAC winch for $149 !. http://www.harborfreight.com/1500-lb-capacity-120-volt-ac-electric-winch-96127.html
I also bought a snatch block to DOUBLE the pulling power (3000 lbs). http://www.harborfreight.com/snatch-block-61673.html However, I did not need the snatch block, you larger, heavier Yammy boat owners may. http://www.jeepforum.com/forum/f27/snatch-block-theory-205210/
BTW, if you type in Google, “harbor freight 20 off coupon”, many times you’ll get a valid coupon code to use!
At first, I was contemplating installing the winch to the studs on the back wall. After discussing with a contractor, the wife and Bruce, I decided installing the winch to the floor was the best option. @Bruce had mentioned a product called red head wedge anchors.
I measured 51" from the center of the trailer axle to the outside edge of the wheel (adding a few inches for space). This is where my center of the winch cable has to lie on the floor (see photo below)
I cut two 24" (base to mount to slab) and two 15" pieces (cross pieces to mount winch to) off the 8' 4X4.
So, based off my research, most garage slabs are 3 1/2"-4" thick. Based off that, I measured 3 1/4" from the tip of the 1/2" masonry drill bit and wrapped black electrical tape to mark my bit depth. Placing the two 24" horizontal 4X4 pieces the proper location as to allow the winch to be placed properly. I used a (speedbore) spade bit and drilled a 5/8" hole on the outside edges of the each of the two 24" 4X4..making sure when I hit the concrete slab and banged the bit up and down (marking the slab). Then I drilled the four 1/2 anchor holes to the pre-measured 3 1/4". Then installed the anchors and then the two 24" 4X4, then vertically the two 15" 4X4's
So the install parts list and pictures are below:
1 – 4X4 – 8’ in length
4 – 3/8 X 6” Lag Bolts
8 – 3/8 X 3 ½” Lag Bolts
1pk – 3/8 Flat Washers
1pk – 3/8 Toothed Lock Washers
4 – 1/2 X 7” Red Head Wedge Anchors
1 – Harbor Freight Winch
Total cost is under $200
Hope this helps some other boat owners. Any questions?
