Interesting way to calm a rough ride.
tdonoughue
The Woodlands, TX 77381
Granted, I am on a slow connection and cannot see all of the videos.... but geez that is a lot of money for a pedestal.
Cobra Jet Steering LLC
Vendor
Florida
About 35 years ago I built aluminum pedestal poles that had 2 different diameters so they could slide one inside the other , then I mounted a motorcycle rear shock absorber that had the external adjustable spring on it .
I mounted the shock inside the tubes so the top was connected to the one tube and the bottom to the other, I put a pedestal style seal on the top and a base on the bottom with a custom made foot rest that could rotate around the pole so when driving the boat it was facing forward and when fishing I could rotate the seat and also the foot rest platform. I built 2 of these and the look on peoples faces when they sat on the seat and realized it had a shock absorber built in was priceless.
biffdotorg
Pelican Rapids, MN
biglar155
Fredonia, WI
As I get older, I'm realizing that comfort is worth paying for. Not sure I'm ready for that much expense for a seat yet, but I'm getting there.
JDFester
Loganville, GA
Our local DNR boat has a version; doesn't look like the same brand, but my kid got a ride and said it was awesome!
BigAbe75
Litchfield, IL
Weren’t there some type of cushion that people were using on Bimini trips? Something to absorb some of the shock.
@robert843
@scot71 Did you find something that worked?
2kwik4u
Georgetown, IN
Keep in mind this is coming from a guy that spent time in R&D in an Aerospace company.......that looks wildly over engineered.
scot71
Williamsport, IN
@robert843
The easiest things to do that help are all of the things that I've already told her. I just need her to do them
robert843
Myrtle Beach, SC
BigAbe75
Litchfield, IL
E-Searider bean bag chairs
Thanks!!! I had a feeling you’d know what I was thinking of.
So those go on top of the captain chair or bench? Would that raise you too high? Or, does the bean bag go on the floor only? Probably be more stable, but tough to see out.
