Interior Question
skbishop90
Alabaster, AL
AR192
OK, maybe I'm Weird, which I'm sure is true. But does anyone have anything mounted in this area? Stickers? Anything? This area just looks blah to me and theres nothing there. In the back areas where the hose hook up is, it has a grey almost carbon fiber print there. I think something needs to be here.
Yea it's pretty bland in white there compared to the rest of the boat. I wished I had the 2017+ interior as it breaks up the white on the seats nicely.
@druppert just swapped out his captains chair in his SX for the bench and it looks great. Just wished it wasn't expensive to buy the new cushions and bench for an updated look.
Have Jet Boat Pilot cut you a piece of Seadek to put on the wall there. I have the old AR192 from before they had the center bow cushion and I always thought it needed something up there. JBP even took care of the templating for me since I was lucky enough that they had one on hand at their factory. Hell, I'd consider ordering a piece to fit their too.
I may look into that. I just need to cut out a template showing the size and shape I want?
Yeah. I would just check with JBP first to see if there is a preferred template material. I know they sell template kits but that seems a little excessive for a small piece like that. You may even get lucky and they will have a boat on hand to template it for you.
I want to follow this. I'm OK with that area, but I'd like something to put in the bow in between the two speakers. Now they have that double thick stuff it sounds like a good compromise to an actual cushion.
