Thanks. Can I assume Yamaha jet boat will have no issue if there are jet skis on the lake?most of the jet boats where you are use Berkley pumps or other similar jet drives that operate on a automotive engine, and they have big pumps and big intake grates but Yamaha uses the same engines and pumps that the jet skies use, also the weed problem usually is near shore so once you recognize the areas with weeds you can deal with them Your model can use my reverse move to clear weeds without needing to open the clean out plugs .
I would not recommend a jet boat on Rice Lake...the weeds on the lake are horrible and dense. I would stick to an outboard.Hi Elliot,
I'm at Rice Lake, Ontario. Canada. I'm not sure what type weeds they're.
I really like the AR series by Yamaha. There is nothing comparable in term of look and space at this price point for sterndrive...
I don't anticipate using the boat much if I buy it. Perhaps one weekend per month during summer months (june - august).
where are you located / use your boat?Got my first jetboat last year and no real issues - going slow sucks them up but going faster just chops them up like salad and spits them out the back.
This past summer late in the season when the weeds were at their worst, I was floating with the engines idling and had a heat warning. Seems the suction was pulling large clumps of weeds over the intake grates and blocking water flow through the intakes. Once I shut down and got the intakes cleared and cleared the warning, I had no issues cruising over the weeds and no further issues the rest of the year. Now if I'm in heavy weed areas, I just make sure I'm using No Wake Mode with the revs a little higher (1600 or 2000 RPM) to chew up the weeds or speed up and cruise over the weeds. So with about 150 hours over two seasons, I only had one instance of weeds clogging the intakes and causing a problem. I had many more issues with the prop getting weeds wrapped around the shaft causing cavitation and lack of thrust than I have with the jetboat...go figure.
I always pull the cleanout plugs at the end of each day, and I usually have to pull a few stringy weeds out that are wrapped around the impeller shafts from mid to late summer, but nothing of consequence.
We trailer to various locations, but this happened in a shallow bay up here in Canada. Someone with experience in Biscayne Bay should be able to advise better.where are you located / use your boat?
I think you are missing the part where you pull the safety cord to turn the engines off.I might be the only guy that would disagree with the use of a reverse method or even a forward burst for that matter, unless you are in open water with lots of room to maneuver and I would never use reverse for any clog.(now) I ran through a debris, some kind of weed like a long(8")bean pod coming off the mangroves.....I felt the forward thrust drop in half and my temp gauge starting rising ....so I thought do the reverse method I have read about out hear, so I reversed and gave it a quick blip of the throttle.
What happened next got my attention rather quick as I was bringing the throttles back up to neutral to forward the reverse gates were jammed in reverse so the throttles would not move into neutral. Those pods were stuck in reverse gate jamming the throttles and gates into reverse that will raise the hair on the back of you neck up quickly.
I shut of the keys quickly as I was in reverse heading towards the mangroves I did a soft landing into the groves and had my wife hold onto the groves so we would not drift....after clearing(ton's of pods) through the ports I had to hang off the back and clean the reverse gates they were jammed with lots of the bean shoot in every small opening not allowing the gates to move into neutral. WON"T EVER REVERSE BURST THE GATED FULL OF CRAP AGAIN.
JMO........ its not safe to clear jets in this manor. In forward with a fully open gate a quick burst might be ok(at lease the gates are not in the way going forward) as long as you are in an area that has an open area that a collision not in the cards (maybe ok), but my advise is clear the jets through the ports by hand(much safer)
