- Royal, AR
- SX
This video will help you to understand how to adjust your throttle cables if they are out of sync from the factory.
@Bruce does this work on the older boats such as my 2008 SX230HO? I noticed up at Lake Powell last week my Port Engine would get up to 10K, Starboard Engine only 9500K, I need to adjust the cables is my guess.
This is the procedure for the 1.8 liter boats. Do you have the service manual? It details the procedure for our MR-1 powered boats. I have been fortunate not to need to use it
The only time my boat was showing significantly lower RPMs on one engine I needed to change the spark plugs.
I do not have a service manual, just the owners manual.
I will find the procedure for you tomorrow. Could you write up the process for others to follow?
Yes, exactly like in the video clip.Mine are off just a bit so I will be adjusting mine soon. I don't have a service manual for the 2015 AR240. Is the adjustment the same? @Bruce
@AZDANSX230HO I know you are done for the season, but did you get this issue resolved? Do your engines "sync" when throttles are locked together? My mechanical throttles are off by 100rpm at WOT and greater rpms diff. at lower rpm. I guess i will wait till next spring after new plugs, filters and oil etc. installed to test/adjust.
@AZDANSX230HO I just acquired a 2007 ar sx230 ho complete service manual electronically, the file you posted is part of it. If you do not have complete document, I can return the favor. It is too large to attach here. 22Mb, 08 should be the same.
@Bruce, your site says these are out of stock, do you know when you will have more?
