Kevin M
- Streetsboro, Ohio
- Limited S
I've been reading all the different audio topics and am a little confused. If i could ask a few questions from the pro's or experienced folks.
1. I bought the amp and from the forums, have a good handle on the physical install of the unit.
2. I also purchased 4 awg red power wire for the battery. Should I wire a "in-line" fuse and if so, what type or amp?
3. I plan on using the factory Polks. I was going to use the amp for the front bow speakers and the cockpit speakers then have the HU power the swim platform speakers and completely disconnect the tower tweeters.
4. I will do a sub later.
5. I'm hoping this isn't to complicated.
Thank you
Thank you
