 - Buffalo, NY
OK Ladies and Gentlemen......Have some questions on upgrading the sound delivery devices on my '17 AR190
First off, the existing system.
(1) Stock head unit
(4) Stock speakers ( (2) in bow, and (2) in rear cockpit area)
(1) NICE Wetsounds Stealth 10 (powered) sound bar on tower.
- Current (4) speakers are powered by the head unit.
- Sound bar has built in Class D amp (200 watt I think)
This has worked OK for the past few seasons. We love the distance the soundbar added to the stereo when at anchor. We're still really happy with it. The rest of the boat feels a little "flat", and needs some added depth, and a bit of "fullness". Large bass hits give us a little rattle from the speaker grills, and you can tell the stock speakers aren't working great. I would like to add some depth to the sound, a little bit of volume, while maintaining clarity. I don't need to rattle the shoreline, or flex the fiberglass (I'm look at you @Hoyt ) on the side of the hull.
Here's what I want to do....
Change (4) speakers to Polk DB651's.....I already have these in hand from another forum member!
Add this Kenwood 5 channel amp. It shows as a Class D amp (that's an efficiency rating right?)
-- Amp will power the new Polk Speakers and Sub from a single unit.
-- Here is another Amp I was considering. Memphis Audio Powersports 5channel
Add this Kicker 8in sub with enclosure. Others here have run this speaker with good success. Will be mounted under the passenger bench seat.
Add new wires from amplifier to speakers (ditch the small gage factory wire). This is a cheap and relatively easy switch that has served me well in the past.
I'm wanting to stay under/around $500 if possible. We aren't audiophiles by any stretch. Our home stereo consists of a mid level Soundbar and wireless sub. The factory Bose setup in my GMC with factory sub is perfectly acceptable and we think it actually sounds good (most people online disagree). Hopefully that shows what kind of sound we are looking for. We don't listen to bass heavy music very often, and are really just looking to fill out the sound to make it a more complete setup. I don't have the budget, time, or desire to really go over the top with multiple amps, batteries, and I don't really want to cut any more holes in the boat at this point. We're big on value in this house, trying to get an acceptable level of performance from not a ton of cash spent.
SO......Does this look like an acceptable setup? Are there better components I can select in this price range that will give more performance per $$ spent? Any other thoughts on this setup? I'm probably a week or two out from pulling the trigger, so I can make changes/adjustments if anyone things it's worth while?
All thoughts and comments welcomed.
(1) Stock head unit
