K-9bot
I bought an old AR230 and took it out for a test run. Both engines started up just fine (in the water) so we started out to the bay. My first observation was that the boat felt like the engines would rev up but the boat wasn't moving as fast as it should. I decided to open up the throttle all the way, the RPM’s reached the redline but the top speed was 42 MPH.
Took the boat back home and started to read and learn about this type of boat and realized that it is a direct drive system, therefore no reverse gear to worry about. I decided to replace the impellers (thanks SBT) since it could be the problem and if not it will improve performance in the end. After installing the impellers it appears that the problem got worse, now the boat was not able to reach even 20 MPH and one of the engine’s oil light was on.
To further investigate I decided to pull one engine out to have a closer look at everything from fuel line to impeller, looking for something like a “slipping clutch” which is what it felt like on the water. The only place that I could foresee such a failure is the Reduction Gear / Oil Pump / Crankcase.
It looks like the bearings in the crankcase have worn out allowing some play between the gears. This would allow the engine to run fast without moving the boat fast, and account for the low oil pressure since the oil pump is driven from the same place…
When I run the boat on the trailer out of the water, there is a metallic clinking sound and it is not from the impellers.
Question 1: Can this be the problem?
Question 2: Does anyone know where I can have the bearings replaced near Englewood FL?
