Link to Taylor made anchor shade review
Checked it out on Amazon, too. Basically, get it from Overtons. Amazon prices varied widely based on colors. Most are $202. Overtons is $130.
The tower setups on an AR vs an LS are very different. And those of us with an SX are SOL I suppose, as the support comes mostly from the tower doesn't it? Seems you could just open the bimini, and lay it across it, extending it either forward or aft per your desire however. Anyone done that?
Actually, I don't think the support comes from the tower at all. They just are overlapping it. This is like an umbrella that is square, with lines off of each corner of the square that go to the cleats. The lines to the cleats pull the umbrella down against the pole in the center.
Now, I do think you will need a base to put under it if you have SeaDek...
Cool find!
Thanks
