Little help with battery hook up please!
MicahH
Grand Rapids, MI
Hey all! Slightly embarrassing but I forgot the stock dual battery set up for my 2016 AR240. I had it winterized in the fall and they pulled out my batteries for me but forgot to snap a quick pic! I remember how to hook up my amps etc but was hoping someone could post a couple pics of how the connections are hooked up from the dealer in the stock dual battery set up? Would be super helpful as I get ready to pull it out for the season and fine tune my stereo setup and addition of a drain LED...thanks!
Awesome, definitely will...I can't see and don't remember...is there a jumper cable that connects the batteries in parallel? I believe it's parallel as you can switch between the start and system battery.
@Chip F. , you do have covers on those terminals normally, right? Please say yes... Otherwise, you should get some. 33 CFR 183.420 (b), plus it is much safer.
Sincerely,
A guy who has dropped a wrench on a battery
I haven't added anything over stock set up but I agree. That's a great idea. Too easy to have something random happen.
Does the pic have covers or is that the proper setup?
Sincerely,
Looks like I will be getting some - Thanks for the heads up!
