Loading 11' ar210 on mfi trailer
aarons1k
Campton hills Illinois
Hi guys , had my boat for 2 years and still haven't mastered loading the boat back on the trailer ! Only got out a few times last year due to have my daughter. I've always ran into the back end of the boat sliding off the trailer. I had been leaving the front to bunks about 24" out of the water.... most of all my Ramps are semi flat so nothing to steep at all . I've had a seadoo and a I/o before and no problems but different trailers of course . I don't usually power load it to bow roller , I will usually get it close and winch it up tight. Any recommendation would be greatly appreciated!!!!
Thanks Aaron
To be honest winching it up is really the recommended way. Yes there are many ways to do it but I've been told to never drive up. I do tho haha. Really with me I just go very slow and to where I pretty much stop within 12 inches or so of the roller and than throttle it up there. But this is not recommended until you get a good hold of what you are doing. Best is to drive up same inches than winch it up. It all depends on how good your bunks are and secured. IMO. More than one way to skin a cat here!
Also I have learned that I am way better pilot without no wake mode on. For me I get better feel of the wheel when I throttle to no wake speed myself. Others might be different but I find it difficult to pull onto a trailer or even maneuver in tight areas with no wake mode on.
If your boat is moving off the side when you're near the roller then you are too deep. If it's because of the angle not being steep enough at the ramp then get some trailer guide poles as they will help keep the boat on the racks.
When I retrieve I use no wake mode on 1st or 2nd detent depending on river current. This gives me maneuverability while on approach. As I feel the boat center on the trailer I will give it some gas to get on the roller. Nothing crazy that's going to cause any issues or ram into the roller but enough to drive the boat up. It's also a good idea to predip the racks and then pull forward. That way they aren't dry and it makes the boat move on them easier. Most launches I go to have concrete a good ways back so there's no erosion from prop or jet wash if you power up.
Some people prefer to winch up the whole way but knowing how thin our fiberglass is and the pops it makes I'd rather not cause any potential stress or gel coat spider cracks over time.
Trailer guide poles are the way to go. Just a hair over $100 with the foam crash pads so you don't hurt your gel. I had a similar problem that would sometimes allow the boat to kiss the fenders leaving skuffs on the underside of the hull. Guide poles keep her nice and straight.
@aarons1k
I agree with @haknslash sounds like you need to bring the trailer out of the water some more. I boat on the Fox River about 30-45 minutes from you. If you want to get together this summer and go over things please let me know.
Yup probably best $100 I've spent on the boat https://jetboaters.net/threads/boat-trailer-guide-on-posts-for-190.10629/page-2#post-192068. I need to get some cushions even though I don't have any rub marks on my rub rails from the PVC. I usually boat on a river with a current but if I had a shallow launch ramp with very little angle you may have to launch deep just to get the boat off. Either way guide poles help make your boating life easier and less stressful.
@aarons1k
Most def !! I would take you up on that ! It will be a huge relief !!! Thanks !!
Awesome thx for info I will be ordering a set asap !!!!
Is there a certain brand ?
Thx for the input I can't wait to mess with it once it warms up here in IL!!
What brand do you have ?
I use Ve Ve guides on mine. I am on the second set. They take quite a beating due to the river current moving the boat around while retrieving.
I believe they are 65" tall. Here is a picture showing the results of a few rough landings.
I just put smith poles on last year after 4 seasons without. We are pros at putting it back on the trailer but after a season with guide poles i am a huge fan. I would call them a must have. Especially nice in a cross wind or river current. Cam
I have these ones on my deck boat they already have the light included. I don't use any on the Yamaha since the draft is so low I don't have to get the rear bunks to deep so its sits well on there at my ramp.
https://www.amazon.com/CE-Smith-Rep...506717&sr=8-6&keywords=ce+smith+trailer+guide
Those are the same ones I have with the LED's on them. I got them for the same price locally at Academy Sports. They have held up great with a season of boating and show no signs of wear.
I'm sold I'll try anything lol
