IN2H2O
- Limited
Welp guys I think I really f'd up. I went to check compression and getting 200 psi in each and then cylinder 3 pumps 250psi. Pull the plug out and it has beads of water on it. I put the other 3 plugs in and idled the motor to try and push as much water out as possible. After about 20 seconds no more water seemed to be coming back out. Are checked compression and it's 200. I unclamped the vice grip at the y fitting. I put the #3 plug back in and now I'm idealing on the hose trying to drive moisture out. Not sure what else I should do?
I think this happened when I was running on the hose with the Y fitting clamped and I built up to much pressure and must have back fed into the exhaust and eventually motor
