Low Pressure Compression Test and Leaking Oil
MLo3
Pittsburgh, Pennsylvania
I took my 05 AR230 to a mechanic after I pulled it out of the water this year and asked them to look the engines over since I hadn't had it done since I bought it. They ran a compression test and reported low pressures on both engines. I had some issues with the oil in the port engine towards the end of the season, it didn't seam like it was holding. I couldn't locate a direct source of the leak so I refilled it once or twice before the season ended. My check engine light would also turn on for the port engine, usually towards the end of my days,
The mechanic said I may be looking at a rebuild, however after navigating the forums, I'm seeing this issue can be common. I'm not very mechanically inclined so I'm looking for any opinions out there on what might be wrong and what measures I would have to go to to fix these issues. The boat ran fine throughout the summer.
Thanks in advance for any suggestions/opinions.
Cobra Jet Steering LLC
Vendor
Florida
What were the individual compression readings and what did the spark plugs look like? Those are the report card of your engine
MLo3
110/90/90/105 port 115/97/100/90 starboard
I had them replace the spark plugs, not sure if they tested before or after. Didn't get a chance to look at the old plugs.
Vendor
Florida
Those are pretty low but all close together ,80 is the minimum you can have. The oil is probably just being consumed. You could have the engines rebuilt or just continue to use it another season maybe go to a heavier oil. As you said the engines are still running ok.
MLo3
When I pulled the drain plug, it was clear there was oil present in the water while it was draining. I'm thinking the oil isn't being consumed.
Vendor
Florida
ok check the oil filter for leaks or the valve cover gasket, the oil filters rust around the crimp area and do leak I put metal tape over them to protect them from rusting
