Do these exist? Hoa rules largely say no boats in backyard visible over 6' fence. Sx230 seems to be bit over 7' on OEM trailer. Can I buy a new trailer to help with this?
My AR230 is like 7'4" to the top of the windshield on the factory trailer. The keel is 17" off the ground. You'd need to almost be dragging the boat just 3" off the road to keep it under 6'. Never seen anything that low profile before.
The limiting factors are going to be the axles and tires/fenders. On my factory trailer there really is no room left to go lower since the tires/fenders fit in underneath the hull. I guess one could remove the fenders and go lower but you'd risk making a mess on the hull or getting two close to the leaf spring axle.
One option is switching to an extra overwide trailer so that the wheels are further out and then the hull could sit lower and if you go with torsion axles, then you could go even lower, but I just don't think you're going to get the boat low enough. some part will still be visible. Also, this would be an over 8'6" wide trailer that could possibly require extra permit.
Another crazy alternative is dig out 1-2 feet so that the spot you back into is lower.
A friend of mine who has a similar requirement to stay under 6' which is also the height of his privacy fence, basically dug it 2.5' and sloped it off his drive. Then he poured a concrete slab on the slope. It looks no different than a boat launch ramp but it dropped it to right at the fence line. he put a drain in the back with some peapebbles and black pipe going out the side and used Landscaping cement blocks for the sides and back. Worked out perfect. Doesn't hold water.
Another fine idea. I tried to "break into" the HOA political community at our last condo. I ran and didn't win. Couldn't get enough support from the 80+ crowd when I was only 25. Figures.
Always wondered if something like this could be fabricated to work on a boat trailer. Neat idea if nothing else.
Here's another airbagged trailer. If you have enough cash I'm sure someone could fabricate this for you. Check out your local "hot rod" shops. They'll know someone that can do the engineering, design, and fab.
It wasn't bad the both of us did it in two weekends, one to dig out and form and the next Saturday we had the cement truck show up and we poured and finished it ourselves. Just the two of us, a bobcat for digging, some concrete finishing tools and a lot of beer. The HOA board was unhappy but he followed their regulations.
It seems that HOA's have too much time on their hands.
Ive kinda accepted I'm going to have to do a combination approach. Probably plant some palm trees along the fence line to get some extra coverage, digging ou seems unlikely in Florida though. My dad recommended building a berm to raise the fence up, but that might be a bit too conspicuous. The other option could be just dropping a giant shed in the back, I don't think sheds are against the rules.
Honestly I could probably do something like this. I doubt I can go down 2 feet in Florida, but an extra foot, plus a shorter trailer... That might work
Research some of the tricks folks used here to get their boats inside of a 7' garage door. As those same tricks may get your SX below 6ft.
The primary trick was to put a caster wheel on the tongue and fold up the tongue jack. That drops the windshield quite a bit. But it also puts excessive weight on the front axle. So most use it just enough to get past the header over the garage door and then put it back up on the tongue jack if at all possible. It's a thought.
Can you plant an evergreen screen along the fence to hide the line of sight? I presume the HOA rules regulate the fence height as well? If the rule prevents visibility of a boat over 6', not the presence of a boat over 6' then I'd focus on preventing visibility ....
At my mothers condo association (75 units or so) a young guy (about 25) inherited his grandparents condo. He ran for president and won. Apparently the 80+ crowd really like him. He talked the board into creating a maintenance supervisor position that would take care of all the odd jobs on the property instead of hiring out the work. Pay would be close to 100k. Which was about what they were paying out to various contractors annually.
He hired himself for the job. He had zero construction experience. It shows in his work.
If it's just inches over, instead of doing all the work, could you not just ask for an exception? Maybe donate some flowers to a common area as a peace offering.
