Maintenance required 100 hours
mraz72
Rochester, NY
Got an alert while driving around the other day, maintenance required or something to that effect, checked the engine hours and they are right at 100 hours. I took a quick look in the manual, I didn't see anything at 100 hours that would cause an alert.
Do you guys know what maintenance I should have at 100 hours? Also, how do I reset the connext alert? I bring it to the Yamaha dealer in the fall and get it back in the summer, they do the winterize and summarize, so hopefully the issue is just resetting some timer.
Flipping through the manual I see quite a few items that require either 100 Maintenance or 12 Month after initial, which ever comes first. Per the attached you could say however I dont know what specifically would throw an alert. Keeping in mind however this manual is what i received with my 2011 242 Limited S. I can certainly say you have a more advanced craft so there may be some substantial differences in what your manual outlines.
Thanks for that, great info. Apparently I missed that page in my manual. But, you did prompt me to call my dealer, they said they do all of the things associated with the 100 hour tasks, so all I need to do is reset the alert. They are supposed to call me back with a method to reset the alert or news that I can't, which would suck because I would have to pull the boat and drive it to them etc..
Found the section in the manual that shows how to reset the alert
97860
No joystick on the FSH210 but I’ll see what I can do or post if dealer gives me other way to reset. Just had alert and it sucks I paid them to do the 100 hour service.
