  • Guest, we are pleased to announce that Lectrotab (Linear Devices Corp.) has generously offered discounts on their most popular Trim Tab kits to members of this Forum via a group by that runs through Tuesday, March 31, 2020. ACT FAST...TIME IS RUNNING OUT!!! Lectrotab is offering 55% off on the list price of any Lectrotab Trim tab configuration you can dream up!
    Click Here for more information>Lectrotab group buy for JetBoaters.net members only
Mantus anchor in storage locker 07 sx230?
capt
North Fort Worth TX
Anyone have any luck fitting an 8lb or 13lb Mantus anchor in their anchor locker?
Beachbummer
Houston TX
Yes. 8lbs will fit in the front. If you make some wedges it will even hang on top.
13 will fit under the cushion, but I could not figure out how to fit it in the front locker without cutting a LOT, so I gave up.
The 8lbs is surprisingly effective on all surface, except a muddy bottom, where it may fall upside down, and not grab on first try. Once it falls correctly it will hold great.
It held my boat in place when dealing with some tanker swells that broke and were pretty big. Water in bow and all. That was the holding power I was looking for, and we got to test it two weekends ago. And the i pound held. I bought the 13 for when it looked gnarly but the 8 had held so well we haven't used it yet as a main anchor.
No wedges yet on the photo below, but with some thin wood I made 2 with a notch on them so the anchor can be placed in there as the picture shows. I added a sort of foam pillow above to keep it wedged in place
capt
North Fort Worth TX
Awesome! Thanks for the reply you have just talked me into ordering an 8 lbs Mantus.
Beachbummer
Houston TX
The 13 would seem to fit if oriented the other way,(and some cuts were made) but then the shank did not seem to fit, so I gave up trying to put it in front. I use a 6ft stainless steel chain with it. The galvanized chain is fine too, but the stainless chain feels and looks like jewelry, so I splurged.
capt
North Fort Worth TX
I had a kinda scary experience yesterday when my stock anchor didnt hold and I had an adult out in the water with a bunch of kids but the adult didnt have a life jacket on and the wind was pushing the boat away faster then she could make it back. I got the a throwable to her but it kinda freaked me out enough to get a better anchor I have had alot of issues with the stock not setting and just dragging.
Beachbummer
Houston TX
Once on the ground with the right orientation, the mantus holds very very well. On my mud situation, once it holds it does not move at all. (At least, so far)
Billtex2000
NJ/PA
Since I got one of these...I rarely have any issue with my anchor slipping!g-p-618b_lg__82089.1558142063.jpg
farrelltravis
Vendor
Norman, OK
We store our 13 pound anchor under the seat. Works fine for us.
