- Lake Ray Roberts, Texas
- Boatless
- NA
- Other
- NA
Trust me, the water lock, water box, whatever you choose to call it, is a pain to remove. The straps that secure it in the rack are simple enough, but you have to release the rubber boot from the exhaust section, through the back engine wall bulkhead, and then release and remove the other end of that boot on the end of the water lock...but that is only half. Now you have to release and remove the rubber boot that connects the water lock to the transom thru hull opening. All of that is after you remove the 26 +/- screws that secure the clean out tray, then release the hose clamps that hold and secure the clean out tubes to the bottom of the tray, and be careful of the clean out switch connections to the tray, which may or may not have to be removed, depending on model. All this just to get to the water box. Once all is loose, you can lift it out and shake it out if so desired to dry. If you remove it, I would just treat it and drain it.
We have two issues here as I see it. Meeting the requirements of the law is more difficult than actually making sure you don't transport the larvae. I will look into how hard it is to snake a hose through the exhaust exit and into the water lock. I suspect this can be done pretty easy for the boats without the resonators. For those, it may take an additional step or two. But the easiest way to do it may be to just rig up a hose attachment like the guys that want to mix in anti-freeze have done.
This isn't the big issue it may seem. Our boats get very limited exposure if you are a trailer boat. Boats that are left in the water...that is another story. But flushing them with a biocide could be an easy solution if those that regulate the lakes would approve it.
