jocolo21
- 252SE
Punch 1,000 Watt 2-Channel Amplifier P1000X2
The Punch P1000X2 is a 2-channel stereo amplifier capable of producing 500 Watts into each channel at 2-Ohms. The P1000X2 amplifier is great with full-range or component systems or can be bridged for use with several subwoofers.
ABOUT THE AMP
FEATURES AT A GLANCE
ABOUT THE AMP
- High level input capable with Auto Turn-On circuit
- 12dB/octave Butterworth crossover
- Features C.L.E.A.N. Set-up
- Optional remote Punch Level Control (PLC2) ready (w/ input clip indicator)
- RCA pass-thru outputs
- On-board Punch EQ with +18dB boost @ 45Hz
- Cast aluminum heatsink
- Muted turn on
- Stealth top mounted control panel
- Short circuit protection
- Over current protection
