Brandon_SC
- Belton, SC
- SX
So yesterday after warming up the engines on my 2008 SX230 it was time to check the oil. Mind you, I check the oil every time we go out, and it was supposed to be full. (I carefully did an oil change at the beginning of the season... and replaced close to what I extracted from each engine.) Whelp, both engines were barely above the low mark. I thought damn, WTF... so my dad and I both checked it 3 times. We added about a half quart or less to each engine to bring them 3/4 on one and 5/8 the other between the low and full marks.
Today, we heated up the engines again on the lake (making sure to troll speed at the end like the manual says)... this time we checked and both engines were barely over the full mark! Does anybody have ideas about why they were measuring inconsistently between days? Going by this the engines apparently weren’t as low as we thought the day before. My engines typically don’t use oil, and I keep them shy of the full mark to keep from ruining air filters. Is there a way oil can be accumulating farther down in the MR-1 engine block rather than the reservoir during usage on the water?
