- Florida
- Other
- Other
most likely you have an exhaust valve stuck open and a piston is stuck up against it. Pull off the valve covers and look for a loose rocker arm that will lead you to the valve that is stuck . You should always turn those engines over in the off season so your valves and valve springs don't have an issue.
