Brad_Ct
- Alva Fl
- SX
Took our 2006 SX230 out on the river for the first time since I bought it 4 years ago (ongoing project). I had no water coming out of the front pisser and very little coming from the rear, after running about 5 minutes at 6.5 - 7k rpm the port engine overheated. Thinking I had a plugged hose I pulled the pisser hose off the exhaust elbow and started the engine and got no water.
My Exciter 220 would shoot out of the hole when you hit the throttles but this boat sounds (as my buddy put it) like the clutch is slipping until you get on plane then it will run at 30 mph at 7k rpm with no problem. I pulled the port pump this morning and measured the impeller clearance at .014 which is in spec. the leading edges of the impeller are pretty nicked up though.
Would a nicked up leading edge cause the cavitation and because of the cavitation not enough water is being pushed into the cooling system? It does not overheat on the hose but it also is not running high rpm’s.
