The VX110 has the identical head cover, head cover gasket, cylinder head, valves, timing chain,, cylinders, Pistons, rod length, piston rings, wrist pins, cases, crankshaft, bearings and oil pan cover ... That the FXHO MR1 has. The only difference on the cases are that there are two stainless water line nipples on one side of the motor and one of those water pipes has a 90° bend on the VX versus a straight short pipe on the FXHO. Coming out of the cylinder head that big stainless pipe is also different shaped on the VX than it is on the FX but they are an easy swap. And on the oil reservoir, the shape of the reservoir cover is slightly different as well as the stainless nipples that come out of it point in different directions than the FXHO. They are however interchangeable if you just do a little fancy hose manipulation to make them plug in from an awkward direction. Then there is a small difference in some of the electronics that plug in on the side of the VX versus the FX but again none of this has anything to do with the oil change purpose of this video and they are identical in that.
