- Royal, AR
- SX
@TwinEngine, do you think the failing solenoids might be a result of the starters failing and pulling more amps?
I do not know what the factory spec should be but it might be worth getting an amp clamp around the wire to the starter and checking how much it is drawing while cranking.
