Konnie
- Tequesta
So I have a 2006 AR230
Don’t use it all that often anymore.
Last weekend when we went for a ride and the port side engine would not rev above 6K rpm for the first hour of the trip.
At times it reved up to the equal rpm of its twin, starboard energize, for a few seconds and then cut back down to 6K. The twin was running at 8K RPM.
The port engine ran fine between idle and 6K but not above 6K regardless of giving full throdle except for a few sporadic seconds now and then when it reved up to the equal of the twin.
But after a hour the the port engine started to run just fine at all rpm levels.
We stopped for lunch for about a hour and a half. Both engine ran just fine after lunch as well.
Any ide what the issue may be with the port side engine? Something similar happened the time before last time as well. But that was the first time it happened.
Regards
Regards
