WREKS
- Port Saint Lucie, Florida
- SX
@RyanTexas, @Babin Farms After running a few minutes on the hose, water should start streaming out of the big hole, upper-right, right above the jet. That hole, as well as the rear pilot, are downstream of the thermostat. I would start by checking the thermostat.
Edit: @RyanTexas My mistake: your boat does not have a rear pilot, only a pilot for high rpm operation. This pilot will never stream water a low rpm. As @zipper indicated surprise that you were able to run on hose at 6k for 15min. Definite NoNo!
