My Trip Down the VHF Antenna Rabbit Hole
Mainah
Chapin, SC
Warning –Long post but well worth the read if you are looking to install a VHF antenna
Primer
In preparing for my first trip to Bimini I wavered back and forth on whether to install a fixed VHF radio. One of my concerns was having the antenna mounted all of the time even though hardly ever used. When I became convinced that I needed to install a fixed VHF radio and antenna I started down the road of researching marine VHF antennas and learned a lot. I will start with photos, where I ended up, and then share some research details around marketing and performance of VHF antennas in general. If you are looking to purchase an antenna then at the very least read the last part.
Where I Ended Up
I have a 2016 242 LS and I want to keep everything looking clean and mount the antenna on the tower. I quickly discovered that most VHF antennas have the cable exiting the antenna above the base (ferrule) and permanently attached. One could cut the cable and add connectors but surely someone had figured out a better way for sport boats should they want to stow their antenna instead of just folding it down. Well that someone is Pacific Aerials. They have two product lines that include the connector within the base (ferrule) of the antenna such that one can just unscrew the antenna. Turns out they make a cost effective 6 foot antenna in black which is the color and length I was looking for as well ( model P6125). Keep in mind that you will have to purchase a Pacific Aerials mount as well given that the cable is connected directly within the mount. The also offer the style with the cable directly attached to the antenna
While on their site I noticed a new version of a ratcheting mount which more streamlined, modern looking, and visually appealing (model is P6759 and there is different model for antennas with the cable direct in the antenna). I found only one online store with a listing for that mount but when the package arrived they had sent me the older version. After two weeks of back and forth with them they could not give me a firm date of when they would have the newer version. I reached out to Pacific Aerials in New Zealand via email and they responded within an hour. They put me in touch with the first US wholesale distributor that would be receiving them and the distributor shipped to me the same day they received the shipment at wholesale cost as a one time courtesy to Pacific Aerials and me.
When choosing a VHF antenna it really comes down to mounting type, length, external material (metal whip vs plastic coated whip vs. fiberglass), and color. I knew that an 8 footer would be extremely difficult if not impossible to stow on board so I went with a 6 foot (1.8 meter) which I know I can stow. I drilled and tapped the holes for the mount into the top aluminum cross piece of the tower (1/4” 20 TPI ¾” deep threads in 1” solid aluminum) and ran the cable from the mount down through the tower. Thanks to @gmtech for sharing how he mounted his antenna. The aft tube on my tower had a partial obstruction likely from how it is made and I had to get creative with a fish tape and wire ties to get it pulled through without making a larger hole in the tower for the cable.
In my opinion it does not take away from the looks of the clean lines of the boat and makes a great flag holder (flags mounted below the radiator inside the top of the antenna) if you can figure out a way to mount flags to it. One could try wire ties but I did not like that idea so I cut, bent, and drilled some thick aluminum sheet I had on hand to make my own custom clamps with a hole tab to clip tiny locking S biners to. I did cut part base plate off the mount because of the mounting location some of that plate would have been just floating there. Not needed but I did cut, shape and polish so it looked like it was made that way. I also choose to use a 1/16” thick piece of 60 durometer rubber cut to size in between the mount and the tower to prevent powder coat chipping and possible metal on metal noise. Probably not needed but I felt right for me.
At the end of the day I spent WAY too much time on all of this between research, chasing the perfect mount, overthinking, and customizing everything but I am super pleased with the results.
The Marketing and Performance Rabbit Hole
I went deep down the rabbit hole and learned a few things. First of all most marine VHF antenna’s dB rating is pure marketing. dBi is the true rating and that is important. Normal gain antennas are half wave type resulting in a dBi or signal amplification/loss rating of 3 dBi. What most marketing folks do is add to that based upon the length of the antenna to get to the DB rating you see most commonly. Longer antennas are better in that they will increase range due to horizon but the truth is almost all half wave VHF antennas have a true signal rating of 3dBi regardless of what the marketing says. So they all transmit the signal essentially equally but a higher antenna will transmit further due the curvature of the earth and line of sight.
Half Wave vs. Co-linear? Half wave antennas have one radiation element where Co-linear (aka high gain) have multiple radiation elements to boost the signal strength. So high gain (co-linear) sounds better right? Well not for most of the boats on this site. If your boat rocks and bobs a lot then this will have a huge impact on the performance of a co-linear (high gain) antenna. Without getting too technical on this one, bottom line is for a most boats under 30 feet a half wave antenna is better.
So at the end of the day one half wave antenna of equal length to another will not perform differently with any human perceivable difference. That said there is a electronic measurable signal loss when there are more connectors and/or more cable length so the extra connector in the mount of the Pacific Aerials and on the radio end to upsize their connector (included) does give it an ever so slight performance disadvantage over an antenna with enough fixed cable to reach the radio with a full size connector. Again that disadvantage is only measurable with precision electronic equipment and is rather insignificant. That said the small connector on the cable end is great for pulling through a tower and the boat. The ability to remove the antenna is a huge plus for me as well. A wire that is much longer than it needs to be will have a bigger impact.
For those still reading I am not making a case for one brand over another it terms of performance, just the opposite in fact. Mounting and gain type will narrow things down then pick length (longer is better), material, and color. Pacific Aerials customer service to one US Consumers email (me) was very fast and had a great result. Their marketing is also not trumped up like other brands. In fairness I did not reach out other brands so can only say they were my choice and I would choose them again over another. Hopefully my trip down the VHF antenna rabbit hole helps someone else.
As usual, this is an excellent writeup. My boat is quickly becoming the Mainah Jr edition :). This basically looks like a factory installation.
Have a couple questions if you don't mind indulging:
- The P6759 Mount: I assume you just cut off a corner of the bracket and then ground/polished smooth? Also, was the pre-installed 15' lead on that mount enough to get the job done, or did you need to extend it?
- If you have a second to expand upon your wire fishing trickery, I love learning new tricks.
- When you get around to it, can you take a close up picture of the flag mounts you put together?
Outstanding work! Do you have a picture of the antenna with the whole boat? I'd live to see how it looks overall. I HATE my antenna and mount....
Yes I cut off and polished the one corner. Sorry no overall photo as I had to wrap up before it rained but will look to get that photo in the near future. Below is a close up of the clamps I made.
1B89EF09-2883-4DCD-9CCF-7B2FEFF68F32.jpeg FC89467C-12C8-4F81-B3A1-45C506804FD2.jpeg
This seems like a subject not spoken about much.
I inserted a small zip tie in the end of the tape before pushing it up from the bottom of the tower then used needle nose pliers the grab it and pull it through the hole.
Yes 15’ was enough with a bit to spare. Think I covered the other questions already.
Fun fact: This is the 5th Google Search result for 'Pacific Aerials P6759', and the first 4 aren't particularly helpful. :)
This a brand new product that I got by non-standard means I was told it should be available by now. I will attempt to reach out to the US distributor to find out who they may have shipped to already.
I pinged Pac Aerials, they said CWR has it, CWR never heard of it. I'm not in a huge rush, but futzing with the boat distracts me from the fact that it isn't yet boating season.
I received the mount from the importer. The importer has to sent to the distributor (CWR as commented above). They are the guys that supply many marine products to the retailers but likely do not sell direct to consumer. I did think I had waited long enough before posting but it should not be too long. I don't want the kind folks that helped me out as a one off thing to get inundated so please be patient.
@Mainah , when you mention first receiving an 'older version' of the mount, was it the P6159B? It looks identical by the picture.
6159 has the longer traditional handle, it looks like. I like the modern look of the knob that Mainah's has.
6159 has the longer handle . The b for that model was to indicate the black cable. It appears that Pacific aerials has started using completely different models number for the different color cables on its newer models. I did order was that stated it was the 6159B model with the picture of the newer one. It was not the newer model.
There are three main differences between the older model and the newer one that make it overall smaller and cleaner. The first is the base plate angle screw and locking teeth (this is much smaller and less obtrusive on the newer model. The second is the arm which again is much smaller and less obtrusive. The last is the knob which is still a cam type action but looks more finished that the old handle style. The base plate and mounting hole spacing are still the same size.
Thanks for the clarification. The vendors I'm looking at must be using the newer picture in the P6159B listings. As with others I'm still in search of a vendor that has it, or realizes they have it, as Pacific Aerials' customer service seems confident it should be available by now.
I have confirmation today from my sources that these are not yet available for purchase but will be very soon. Sorry for jumping the gun.
Cool, thanks for checking. Guess I can pick up the rest of the goodies in the meantime.
PAC got back to me:
We have an order of these mounts shipping to CWR this week and they are in the process of adding to their dealer website, if they have not done so already.
They should be available through CWR any moment now.
<Importer>
