MrMoose
- Calgary, AB, Canada
In the past, I've used a syringe to inject grease into my steering linkage, but yesterday, as part of checking my impeller bearing for water ingress, I took the linkage apart. The attach point on the nozzle has two white nylon(?) bushings in the bolt hole. One bushing inserts from the top, and the other from the bottom. Here's a pic of the top one, slightly pulled up for demonstration purposes:
My port nozzle had two of these (one top, one bottom), but my starboard only had one (top only). I can't say whether it came from the factory this way or whether it was lost when my dealer pulled my drives apart to fix leaks.
So, I looked at the Yamaha parts diagrams, and this part is not shown. It might be part of the linkage sub-assembly (GP1-U1406-00-00), which seems to be a pretty expensive route to go as I think that it costs around $80.
Any idea where I can get just the insert? It seems like a pretty customized part as it seems like that diagonal "crack" is supposed to be there. All 3 of my inserts/bushings looked identical. HELP!
