Need good ideas on repower issues - help please
andyak1
houston texas
I have ar210 2007 bought with blown port engine.
Just finally got YDS up and running
good news - starboard shows boat has only 126 hours on it
the repowered port engine has 76 hours and is using ecm from ski as the boat ecm is
repower Port engine is erratic in that it bogs down and only runs up to 9000 plus rpm after first started, then bogs down and won't go over 2500.
Looking at YDS - the good starboard engine has very stable timing at 5 btdc at idle and increase when throttling up.
port engine has timing jumping around over 10 btdc at idle and seems to be erratic.
This port engine was in a ski that was totalled because it fell off lift into lake - so ski was in water for awhile. I have clean oil now that has stayed clean through all my testing. I replaced the oil cooler with a fresh cleaned one and took off pan and cleaned it all out with new gasket.
any ideas why timing would be erratic? I guess this would either be the problem or the symptom.
HELP PLEASE :)
Andy
swapped ECM and CAM sensor today. No difference. Timing jumps all over on YDS from 10 BTDC to 28 BTDC and all over in between constantly moving around at idle.
When first started it will rev up over 9000 rpm stable. then 20 sec later will not go above 2000. and bogs down with timing all over.
Could it be bad stator power? Good engine had voltage over 14 when running. this engine voltage was like 12.9
at a loss
You could unplug the rectifier to ensure that's not it. (I doubt it)
Compression check? Spark plugs OK? Leaky injectors? Fuel line swap with other engine?
Wild thoughts, hopefully others can provide more insight.
Thanks - yeah compression was 181-185 all cylinders right before install. 3 sets of plugs,
another set of injectors- then tested them in YDS and- all right around 12.5 ohms - I could put bottles over them and crank engine too see if any are leaking - but seems unlikely
Ran off of other fuel pump
swapped voltage regulators
still at a loss.
I wonder if the timing is off mechanically. When I had valve cover off I noticed 2 extra black dots on camshaft by the factory dot - I did not think on it because I thought engine was all set... but now I wonder...
Will it run in no wake-mode?
Well, both cams were off by about 2 teeth!
from the extra black marks on the cam I think some joe pro tried to set timing -- wrong. I was able to reset to correct by removing exhaust cam and pulling tensioner out on that side and loosening timing chain tensioner on intake side. I used a dial gauge and found TDC. Then was able to set intake cam correct and after a lot of finagling I got the exhaust cam in and set correctly.
Result: Started right up and now runs correctly!
Nice!!! I was thinking about you... Everything seemed to be just fine outside the engine, looks like the issue was on the inside after all.
