jlcj7
- Tega Cay, SC
- SX
Ok, so i guess i have hit my first snag with my install... I have no power at the head unit and when i turn the battery switch on now i heard feedback in the speakers...
I installed the Polk speakers last weekend and the Blue Seas battery switch and ACR (with 2nd battery). Everything was working fine with the stereo and speakers... I also changed oil and spark plugs today before the amp install and again everything was working fine...
So today i began the Clarion XC1410 amp install...
Here is what i did:
The head unit does not turn on anymore when i turn the battery on... I obviously have wired something wrong today with the amp, but confused as to what...
Any ideas to help me fix this?
Here is what i did:
- Ran power wire from house battery side of switch to the amp
- Ran negative wire from negative bus bar to the amp
- Connected RCA cables from head unit to amp (input)
- Cut speaker wires after plug on head unit and wired them into the amp (white, Grey, Green, Purple both pos and neg) and wired into output side of amp... that then run to speakers
- Wired Blue wire from head unit (after fuse) directly to blue wire on the output side of amp
