Need help/confirmation
LakeTravisBear
Austin, TX
About to order my performance parts for my 2019 AR190. It has the HO motor so the guy I Riva told me that these are the parts I needed to order. Anyone that has done these mods before do these look that the correct parts? The guy on the phone said he didnt know if they had tested the Lucky 13 Cone on the HO motor for a boat just a ski but I told him I thought people on here had?
https://rivaracing.com/search.html#!sq%3DRY12040-IMUK%20
https://rivaracing.com/i-20765822-lucky-13-pump-cone-yamaha-sho-ho.html
Yes to both. Plus you can run over to your local oreilly store and pick up a direct bolt on K&N conical filter for 50 bucks and then you’ll be getting the most bang for your buck out of the ribbon/spark arrestor delete.
Will that replace the square filter I have listed or is this an add on?
Will any cone filter work or is there a certain one?
A cone filter would replace the stock air box. I believe it’s a 3.5 inch opening so that’s the size you would need, just need to measure the size of the opening to be sure you get the right one. Mine is a 3.5 for example.
How much louder did the K&N make your Engine?
You can definitely hear more air moving when the engine is under load (above 5K rpms) whereas any gains in performance felt by removing the ribbon delete are negated by the stock air filter if it is not replaced by the aftermarket cone solution.
