Hello all. Need some help. Long story short my 05 sx230HO blew a ecu about a month ago. Installed a new factory ecu and replaced the #3 coil and put new plugs in it. Only able to get 8k rpms on that same motor. Any suggestions?
Check to make sure you plugged in all the coils. I had same behavior after changing plugs but didn’t fully click in the coil. This was an aha moment for me on the water and an easy fix.
No I don't have a YDS. I did send the ecu off to be fixed but came back unrepairable. I have tried 2 different set of plugs one brand new set yesterday and a old repair that were new at the beginning of the year.
No not sure the cause of the ecu. Gas and oil are fine. After replacing the ecu I did notice that #3 coil was bad and causing a misfire but I did replace that with new plugs.
@cjssho Where are you located, there may be a member here with YDS that would run the diagnostics for you. I do agree with all that @Scottintexas said esp. about gapping. Is there a chance you were sent the wrong ECU, maybe for a non HO motor? Just bringing it up, It is the same wiring harness p/n for both ECUs. The numbers I looked up on Yamahasportsplaza are for HO's 6P6-8591a-01-00 and for non HO's it is 6B5-8591a-01-00. I do not know if it would even run with the wrong ECU, others here have a better knowledge of this. Another suggestion is to unplug each spark plug, only one at a time, maybe starting with #3 to see if it changes the idle/running for the worse.
I'll try the the spark plug thing and see what happens. I did order my ecu from Yamaha sport plaza and part number was correct. My plugs are the ngk iridium so I thought that they came gapped to specs. Thanks for all the suggestions. Keep them coming.
maybe I should be more specific. You're right @Jgorm theyre actually 3 different variations of the mr-1 engine that I'm aware of. There's a 150HP HO, 130 HP & a 110 HP. My non-ho 110 hp engine that were installed in the 210 series boats have a max rpm of just above 8k rpm's. But it's quite possible that the wiring harness wouldn't even plug in to your ECU anyway @cjssho.
Anyway, hopefully you've figured it out by now. Best of luck with it.
HALLO
Lately i bought YAMAHA SX 230 ,year 2005 ,with 2 engines .I'm looking for hole electric box with wires .because i have only one ,box is called YAMAHA 6B6.
MODEL of boat SRT 1100-D. VIN YAMCS384D505
Computer in the box has these numbers :6P6-00, F8 T94874, 5129
Outer computer has these numbers : SH 678B-13, G4D.3
Do you have something like that ?I can send pictures if you like .
Iam looking forward for your replay .If you don't have it ,do you know where i can find it ?My mail is roman@wiertelak.pl
Kind regards,
Roman
HALLO
Kind regards,
Roman
