Need help with an amplifier
H2OBoy
Lake Oconee, GA
So after turning on the Infiniti stereo in my new boat, I quickly found that I will need some type of amplifier. It is not nearly as loud as the cheap Clarion in my old SX190 (which was lackluster at best). I would like to install a small amp to help with the volume. I have no interest in installing some extensive sound system that involves more wiring than a simpleton can handle. Any thoughts on a simple amp that is easily installed with minimal wiring, and without having to install a second battery? Plug & Play would be ideal...
H2OBoy
Lake Oconee, GA
I am surprised that the infinity stereo has less output. Have you checked the specs? Are you sure it is wired correctly?
H2OBoy
Lake Oconee, GA
The boat was just delivered this morning so I have not checked much. I certainly would have expected much more from the Infinity stereo. I quickly paired it to my phone and streamed some Pandora to test the sound. I was not impressed. I will have some time over the weekend to inspect further.
Sometimes Bluetooth volume is low. Try another source.
@H2OBoy I know the boys here are going nuts about those Kenmore amps.
Another option, and a road well traveled in this forum, is to go with one of the Clarion XC1410 amps. Those are solid for a budget system and about as simple as it gets.
There have been several good write ups, the one from @eticket's 212 is probably my fave.
Just saying - a different option.
@H2OBoy And congrats on the new boat! That was fast.
subysti
east Longmeadow Mass
I played with one of these at the dealership and it didnt sound that bad. I'd check all the stereo settings first. I know that with Bluetooth the device usually defaults to a mid volume setting, I'd check your phone or iPod volume while its playing then go through the the stereo settings. Maybe the loudness is turned off.
zipper
Boston Whaler
Kenwood...I don't remember doing a stacked washer/dryer combo mod. to the boat.:winkingthumbsup"
H2OBoy
Lake Oconee, GA
Thanks and thanks!
H2OBoy
Lake Oconee, GA
I will check this again and see if something is not in range. Thanks for the help.
