Colin W
- NE Pennsylvania
- Glastron
- GT
Looking to buy an anchor for by glastron GT187. Looking for suggestions or info. This is our first boat
Other than the pain of the heavy weight, I use a coated 20lbs Navy Anchor with 6ft of stainless chain. It's quite compact, and holds really well!!! It's just heavy, but it fits in the anchor compartment, which some others do not. I have had the Navy Anchor drag a bit with very large swells when anchored facing big swells from large tankers in an island facing the ship channel. It reholds right away, so I've been thinking of trying the 17lbs Mantus or 13lbs Rocna. (Have not yet decided) The 20lbs Navy anchor is around $40 or less at Academy if there is one near you. As I said, It's not as popular due to the weight, but I find it a worthy anchor. I have a 20lbs for main, and a 10lbs for the stern, or emergency as needed if I lose the big one.
It's tricky to use a rear anchor with others that are not using one. They will swing and you won't, so they might hit you as they swing when the wind changes.
How big is your box anchor?
Thanks for sharing! Glad it held!
