Welcome to Jetboaters.net!
The steering wheel pulling to port makes it seem like the port side engine/pump isn't delivering proper thrust. I was referencing the reverse gates in case the cable on the port one broke and is stuck in reverse (or stuck half way). If the port steering cable came loose or broke it might give a pull to port also.
Loss of thrust could also mean that you sucked up something in the pump of course. So hopefully you can investigate further when you find a beach. Be careful, if it's cavitating you could overheat the engine. Check the pee holes for proper circulation.
Now that I think of it, you'll probably need to disconnect the cable from the bucket to prevent it from wanting to be pushed down next time you go to reverse.
It will be much harder to back up with only one engine, but you could still make do if you're in the middle of a vacation.
BTW I assumed that the cable broke. But it is possible that it just disconnected itself from the throttle controls. You might be able to pull the throttle controls up off the helm and check it there. If it is still attached, then it broke somewhere in line. But maybe you got lucky and the nut just fell off.
Hopefully you get it all sorted out so you can either get it back on the trailer or continue your vacation.
Actually it is still connected because I can move the bucket by hand and make the throttle move with the wifes help. So it must be on the way out or needs some serious grease
You can disconnect the reverse gate easily without any tools and simply leave it in the up position and go on your way until you can fix it. Just make sure to wedge something or use wire ties to keep it in the forward / open position. If you do this, just make sure to not use that engine for manuvering around the docks because it will only go forward thrust regardless of the throttle position.
I'll be away from the computer for a few minutes but call me if you need step by step instructions on how to release that reverse gate without tools. It takes only a second.
