slow speed rooster tail / jet adjustment
aleestma
252SD
My 252sd is throwing a rooster tail at no wake speeds. I have people telling me to trim down, embarrassingly. I do have thrust vectors but I can’t imagine that this would cause that. Is there an angle adjustment for the jets?
zipper
Boston Whaler
Looks to me it is the port side. Do you have any pictures of the jetpumps and TV's? There is no trim. Something is not aligned (nozzle/bucket) or hung up (TV's).
HangOutdoors
Royal Oak, MI
Pic the the TV, something is amiss I bet with them or your bucket has an issue.
David Martin
Punta Gorda
The jet nozzle is close to the surface......Mine has w large wake behind it especially if I have a few bodies up front in the bow lounge but that looks larger than normal..............kinda looks like a steering thruster may be stuck up in jet nozzle spray allowing water to ramp up in a rooster tail.
IA_210SX
Iowa
Cobalt
I used to see this as I went into the marina in no wake mode. Annoyed me but did not make a huge difference.
lazergeek
South Florida
To much weight in the bow?
IA_210SX
Iowa
Cobalt
not really. To be honest at no wake mode the Yamaha’s always seem to ride a bit nose down. Watch the Miami boat ramp videos on the the YouTubes and you’ll see the dip. Never had more than capacity on our 21 footer and it had a propensity to dip at low speeds.
lazergeek
South Florida
you cant use Miami Boat ramps as an example, the Yamaha's on thier always have 10+ people in the bow, lol
drewkaree
West Allis & Fremont, WI
@zipper has the side right, I believe, which brings up who else is in the boat with you. If nobody, in that pic, or in the bow, then reorient the passenger(S) and see what your result is.
You are the ballast, if you're alone, and that would be why it's most prominent on the port side - your weight is keeping the starboard nozzle in the water.
You can also adjust the nozzle to toe in/out, and it may help with the spray. Slightly inward toward center for both sides will concentrate the wash.
Not certain if they've updated the nozzles for slightly directional thrust with the newer boats, but a side view at the nozzle may show you that it can be rotated (possibly assembled incorrectly?), it's worth a look
It shouldn't have anything to do with your Thrust Vectors. Pics of your nozzles from multiple angles would help as well
