New boater needing help...
Tronics212
Good Sunday to you all! I have a 2020 AR210 (5 hrs) I’m out on the water and we are anchored. I go to check the water temp and depth. To find the monitor will not come on, engine start just fine but I also have no rpm gauges. I do not have my volt meter but I have checked all visible fuses. Also check the fuse box on one of the motors. Can seem to find out what’s going on. There is a lot of shallow areas so I’m nervous about getting back. There are some black fuses behind the cockpit which I can’t see through labeled (res 3 & 4) I think they’re fine though. I can unplug the monitor and plug it back in and it beeps as if it’s there but I can see anything. Any ideas [USERGROUP=9]@HELP[/USERGROUP]?
Thank you. The entire screen is dead, shows no sign of life. Usually when I turn the key I hear a serious of clicks and Yamaha loading screen appears. I get nothing at all no audio or visual that it’s on. No dual batteries yet, but I work in low voltage and know my way around electronics. I have a dual battery setup in my truck. Thanks for responding, I thought this was a some what out on the water thread, my fault. I know I can get back but it’s a risk. The boat runs fine from what I can tell. Just no warnings should I get too hot or too shallow
[USERGROUP=9]@HELP[/USERGROUP] for @Tronics212 Is that helpful?
No, OP, you did it perfectly. Putting the 'at' help is what sends the note to everyone.
Have you turned the electrical/battery switch off for a few minutes and back on? I'm not a Conext expert (don't have it on my boat), but rebooting is always a good first step with a computer...
Yes sir I started with the battery disconnect for about 10 min and tried again, nothing. So I just disconnected the all connection from the battery for an additional 10 min and still nothing. It’s strange to me that I lost the gauges as well. Makes me think a fuse but all the fuses by the house battery are good. Well there’s only one of the three that would fit the criteria (main) the other two (radio / bilge)
The gauges are connected to the screen and the ECU and everything by a bus system. You may have jarred loose a connector somewhere or the terminator on either end. But that is pretty rare (they are waterproofed connectors with locks on them that you need to squeeze to disconnect). But if you are disconnecting and reconnecting and it is beeping, a disconnected connector seems unlikely.
But if your Connext went out, it may be interfering with the bus, which may be why the gauges don't work.
And everything was working on the way out, I assume?
If you have a cell phone with you, might try to download Navionics. They used to have a free version with basic maps that may show the shallow areas. Or drop the $20 or whatever on maps for the year. (I don't use it anymore--got a chartplotter) You may be able to use that to give you some idea of depths on the return. Then you can figure out the electrical problem in the comfort of your own dock.
That makes more sense in regards to the bus and no rpms. I did trace the wires and check all connections. Yea everything was great, I worry about depth where I’m at so I am constantly monitoring it. I was watching it when I anchored. I had it off for about an hour. I also wasn’t using the radio. I was using my Bluetooth speaker. Almost thinking I lost the whole monitor... that seems to be the resolution for similar post elsewhere. I appreciate the responses. With it beeping while replugging it I would think it’s not a fuse either....
Found this:
A covered block with three fuses and 2 relays should be mounted to one of the bulkheads in the battery area. The one you are looking for is the first yellow fuse (20 Amp). There is also a separate fuse mounted to the bulkhead in the same area, but that is for the ballasts. There is a similar looking block located by the SPU, but that one only has resistors.
Thank you, That was the first place I looked. Next to the battery disconnect I have 3 fuses but that’s it. One says main and it’s yellow 20A, I even went as far as taking the 15 amp out of the radio (2nd fuse) and replacing the 20 even though it looked perfect. The 3rd is for the bilge pump, it’s a 3A. I would think that I wouldn’t get a reconnection beep from the computer if it was a fuse.
Can you give out your GPS coordinates?
I figured I could search on the computer probably better than you can on a phone on the water....
Ok, so with the easy answer out of the way.... I think I am back to a dead screen. Sorry... unless someone else around has other ideas?
I’ll look into that. I’m at a lake where they sell the water so it’s down about 20% from when I was here 2 weeks ago. Crazy...
Wry true and without being able to monitor the batteries I don’t want to risk charging my phone. I do have a jump pack but I’d rather not run the battery out. Thanks for your help, I truly appreciate it. Think I’m going to try and just limp back
I’m in south Texas at Medina lake. Both engines run so I’m just going to get back to the trailer. Thanks for your assistance! Not looking forward to trailering it to the dealer though. It’s a couple hours from me. I’ll post. Resolution once i find out
If that is helpful at all... Rather big .pdfs, tho...
I think the connext screens are sensitive to voltage. Could it be your battery volts are low due to running radio or inadvertently leaving something on which drained the battery below the threshold the connext screen likes? I would check voltage as soon as you can figure out a safe return.
