4x15mph
- Downingtown, PA
I think I had a jam in the impeller housing yesterday and my impeller, plastic liner is pretty ripped up. I don't think the impellers were ever replaced and they do have a few dings plus they aren't Solas . I may take this opportunity to change out to Solas concords or another option. My impeller ducts have some fins that are not "whole" so I may think about changing those out based on the feedback here.
I have an 2001 LS 2000 with new impeller housings and plastic liners. Stock engine setup with no performance mods
1) I will replace the plastic liner(s). Has anyone done this and what do you recommend as far as getting the old liner out?
2) Any recommendations on specific Solas impellers from an LS2000/LX/AR210 owner or previous owner? I read that RivaRacing can help but I wanted to get feedback on concord vs. the "x" model. I have a stock engine. We do a lot of watersports while I also like speed. According to the Riva site, it looks like the LS2000 would use: YD-CD-12/18.
3) My impeller duct assembly (fins that sit in front of impeller) have chips out of them and they are not completely whole. See the attached picture. Will I see a big difference in replacing these or could I think about staying with the older ones while still seeing an improvement by the switch to new Solas impellers?
4) how easy is it to replace the jet pump bearings? I see they are inexpensive but it sounds like they require a press and I am not sure whether this is something to try on your own or should I think about getting a press (i.e. harbor freight). Easy enough or risky with new Solas, new bearings, etc?
