Cmonst
- SX
This is turning into a very frustrating situation. I purchased a new/rebuilt yamaha MR1 HO motor for an SX230HO from SBT and it will not start. The motor turns over, verified spark, fuel injectors are spraying, fuel pressure good and compression on all 4 cylinders, the only thing left is timing. Also verified through yds that all sensors are functional. It does not backfire which leads me to believe the motor has a problem with the timing. Other notes... the previous motor was replaced because it threw a bearing, this was verified by SBT when I turned in the core, also I did run the old motor before pulling it to get the oil warm and suck it out. Transfered all the accessory parts after cleaning and replacing all seals to make sure all the metal shaving from the old motor were gone this was not difficult, dropped the motor in and no start. Now after speaking to their tech support department and explaining the same as above they need me to repull the new motor and send it back to them my expense, that just got picked up March 25 and completed the install two weeks ago. I spent the last 2 weeks troubleshooting the motor and verifying it wasn't some other part of the system everything checks out. So my question is how can I verify if the timing is off without disassembling the block, I will of course be removing the accessories but after it's stripped down is there a way to verify if the timing without disassembling the core, suggestions are greatly appreciated!
