MTN2lake
- SX
Hello all!
Long time lurker, first time poster. Bought my first boat this week; a one owner 2005 SX230 HO with 280 hours on it. Garage kept and impeccably maintained; the previous owner had a 3 ring binder “log” of every bit of maintenance he ever did on it, including annual oil changes, rebuilding the clean out plugs, etc.
I’ve been reading up on boats and the wife and I settled on a Yamaha Jet Boat primarily due to the reliability of the MR1 engines, the general good regard for the platform, and the deal we got on this particular boat. We have two kids under 4 so this was a family investment. We’ve been renting boats for the last couple summers (mostly pontoons) and wanted to go ahead and pull the trigger.
We took the boat out for a water trial with the previous owner and it performed beautifully, we also got a lesson in checking the plugs and the owner had them out and did not reinstall them before we were on the water. He showed us his protocol for loading and unloading and we plan to go to a local boat ramp in the early spring and load and unload 5-7 times with a checklist to get the procedure down with no pressure. The prior owner even helped us winterize the motors before we drove away.
Then, of course, the SNAFUs began. 40+ mph wind gusts on the drive home pulled the stern cover off while driving and yanked 6-8 of the snaps out of the side of the boat not 20 mins after we pulled out. Worked it out on the side of the road, stowed the cover, and drove slowly home watching for flying cushions. Got home successfully, exhausted, covered everything up as best we could and went to bed.
I woke up the next morning and went out to look at the boat and noticed it was below freezing. I immediately panicked about water still in the boat, specifically in the clean outs and pulled both plugs. Water ran out, but I have no faith it did not freeze in the clean outs. I have visually inspected them extensively and do not see any cracks.
Here are my questions:
1) did I majorly screw up by leaving the water in the clean outs to possibly freeze? How can I tell before I put the boat back in the water?
2) it appears the solution to the pulled snaps is to remove the old rivet shanks, install repair fiberglass(bondo-type stuff, unclear on the exact name), and reinstall new snaps. I searched but could not find a thread on here discussing this issue, any feedback appreciated.
3) last owner installed a permanent trickle charge outlet in the side of the boat. Should I plug it in all winter?
4) I plan to test the batteries before use, but does anyone make a habit of carrying a charged jump box with them?
More questions to come, I am sure.
Thanks in advance!
Thanks in advance!
