Nightmare
- Southern California
- Limited S
Hello everyone, I have been lurking for the last couple of weeks reading about Yamaha jet Boats. We found a couple for sale in So Cal, but everything is going so fast we were "outbid" on the first two boats. My wife ran across a 2011 242 on F-Book. There were some communication problems, but we finally set up an inspection last weekend and closed the deal on Saturday.
I assume this boat has an interesting history and we only know the last part of it.
2011 Yamaha 242 Limited with 11.3 hours on the motors...
We purchased the boat from Mr. H in May 2021
Mr. H purchased the boat from Bert's Mega Mall on 9/27/2020
Mr. H tells us they used the boat one time in the ocean and decided they didn't want to do that again. Mr. H threw in a full set of scuba gear with the boat (Scuba Pro) with everything except the computer.
Mr. H managed to rip/destroy the bimini top for the boat and ordered a new one from Berts. I will get the top IF/when it ever arrives...
Overall the boat is in pretty good shape. There is some weathering on the gel coat and the passenger cup holder is sun-damaged. But all the upholster appear to be nearly new. The motors start right up and showed the 11.3 and 11.5 hours on the clock. BUT literally, NONE of the other electronics worked. No Radio, blower, switches, etc. Mr. H thinks he may have wired the battery wrong after cleaning the boat. I assume it must be something like that and it turns out he just connected 1/2 the wiring to the wrong terminal. We close the deal and take her home. I spend the next couple of days cleaning up the boat and noting any issues.
We drove to Bert's and got the paperwork submitted to transfer ownership on the ordered Bimini Top. Bert's also gave us Mr. H's Repair Order and the Internal Repairs prior to the sale in 2020 (or the M.R.S. Performed by Bert's).
Mr. H reported that the boat was taking on water. Bert's found the Emergency Rear Hatch was leaking and they resealed it.
Bert's spent $5,800 on the boat before they sold it. The main things that jump out are:
Upholstery - $900 - They obviously re-used the seat bases and probably the cushions.
8 Injectors - $925
Fuel Pump Comp - $225
Awning - $680 - So Mr. H destroyed a brand new Bimini...
Radio - They replaced a couple of speakers and the receiver with a Boss
Batteries - 2 new
Sound-Proof 1,2,3 - This DOES NOT appear to be installed. I'm not sure what to think
So after a week of cleaning and stuff, we finally took the boat out today.
We failed the Zebra Muscle test at the first lake. There is water down by the motors even after drying it out multiple times. I'll ask about that later.
We are able to take the boat to another lake and we had a good time. It performed well. The launch was nice and easy. The kids had a good time on the tube. We even towed another boat about 45 minutes back to the dock due to an engine failure. Got loaded back onto the trailer with no problem even with the winds picking up.
SO, here are a couple of questions I have at this point. I'm sure there will be more.
1 - Is there any easy way to tell if my 2011 has the Oil Cooler Bolt problem?
2 - The Port Engine runs at a lower RPM than the Starboard when the controls are at the same setting. Is there an adjustment?
3 - What should I do about the missing sound deadening? Is there a better product than the foam Yamaha installs?
4 - What audio system are you using to replace the factory system? Do any of them use the control on the transom. The BOSS system does not.
5 - How do I get all the water out of the sump area? I parked the boat on a pretty good hill and let it drain. I can't even see where it is coming from (Somewhere behind the main ski hatch. Under the Gas Tank?)
6 - The boat didn't appear to take on much/any water today. But I see an old water line by the gas tank. Is there anything else I need to check?
7 - Anything major I am missing? I haven't owned a boat for about 15 years.
Thanks. Here are some pics
8 Injectors - $925
Batteries - 2 new
