Progress report 1:
- added marine stabil to the fuel (the tank is full of 92 octane)
- cleaned out the trailer locker which had a gallon of Seadoo 2 stroke oil along with two vests and the pwc cover in it
- removed a mass of line from the drive shaft with dremel, took at least an hour
- discovered that the pwc has an aftermarket top loader intake grate by worxs
- the impeller looks good and maybe aftermarket since it is polished
- noted a visible hole in one of the small lines attached to the exhaust
- noted one of the head bolts had high temp silicone on it, as it turns out this bolt is damaged / partially stripped
- pulled the head expecting to see the top of the first piston and the dome of the head above it spattered with metal fragments (from a failed piston ring or worse crank bearing) but both look good as does the side wall of the cylinder. The low compression (first cylinder is at the bottom of the pics)
- as expected, the tops of the two pistons, the domes in the head and the spark plugs are different in color (rich v lean). The dome in the head over the first cylinder with the low compression is the one in the top (the black one) in the pic.
Since the piston, head and cylinder look good I'm not sure what is causing low compression in this first / front cylinder (60 psi v 120 psi in the second / back cylinder). Hopefully, it just a gasket failure and not a hole in the block.
Any ideas/thoughts?
Next steps
- reinstall the battery which has been charging overnight to see if the spark plugs are firing and the variable trim system (VTS) is working
- prep the pwc (loosely put the head back on), cover it and move it and the trailer out of my garage
- take the bundle to a pwc shop that I trust, The Ski Clinic. The inspection/ diagnostic fee is $120ish for an hour of labor but they will be able to identify the problem(s) faster than I. If it is something that can be fixed for $850 or less I will likely have them do it, if the repair cost is higher I will put the bundle up for sale.
- If I keep it I will sell or trade the trailer for a shorter one, replace the original plastic mats with hydro turf and add a splash and keel guard, I will also replace the wear ring if the ski clinic recommends it.
