Roof Man
- Dallas, TX
- LS
Mechanical in nature, but have not owned a jet boat before! (I know, I know ... what was I thinking!? lol)
Have read about doing the Pre-mix conversion (getting rid of the oil tank and all) ... right now, it "may" be an option, as I found that, looks like the oil reservoir is filled with "4 stroke" Yamalube! (boat has 2 - 2 stroke engines!) Sigh ... another thing to do on my list. Not sure if I'll get it on the water this year ... (
So I assume that I have to empty that out as much as I can to put the 2 stroke oil in. May think about the conversion now. LOL
ALSO... if anyone can respond, Questions!!!
* Yes, need both windscreens / windshields, if anyone comes across them!
1) So you can't buy a spark plug wires to replace the old ones, as in auto's!? (I see where I can send the wires/coil covers in to get redone)
2) Are basic "high flow" Fuel Filters ok to use!? I assume a 1/4" line (can't find specs on any of the layouts online of the boat), without paper in them? They go for $2-5each, where-as anything Yamaha branded (even the 3rd party fuel filters) are $25ea+
3) Assume to TRY and use Ethanol free gas, if I can find it. Trailering the boat, and won't be used as often as most do. Will use StaBil
4) Anyone know of a person/place to get "hands on" help!? (Dallas, Tx area) A place close that works on these, says he's booked into January! (wow!)
5) After I moved it, pulled it to a new home on the trailer, had a strong smell of gas, but couldn't find any anywhere... hmmmm
6) Seems all wires are hooked to "one" marine battery, and there's a new smaller one, but not hooked up... a problem!? Can both engines work off of 1 battery or does it need to be wired to 2/both at all times?
7) Have ordered new spark plugs... IF I get it all started/running, just use them as is for the short time remaining this year? Or go ahead and replace them now and also use them next season?
8) Still need to "change out" the oil lines (if I keep them! lol) There was a place to order a "kit" for this/these wasn't there!? And the gas lines too? (and more!?)
9) Rear sear back seems to be "falling." Any way to repair or fix the support or frame of that? (without replacing it)
10) Etc etc etc .... sure I'm missing things but ... whew, got myself into a "time machine" for sure!
Thanks for the help and guidance!
